Gas gauge stuck
Discussion in 'The Garage' started by cegusman, Jul 28, 2003.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    This weekend I layed my k5 on its side. It had about half a tank of gas, now the gas gauge needle is stuck way past full. I have filled up the tank since to see if it would fix it, but no luck. Could I have screwed up my sending unit in the tank?
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i have outlined the way to fix this numerous times.
    1. take steering wheel off vehcile with broken gas guage
    2. Push said vehicle off cliff
    3. Install steering wheel onto vehcile with operating gas guage
    4. Pop a frost brew to congradulate yourself on your sucessful fix.
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    sounds like your ground wire came loose /forums/images/graemlins/eek.gif any pics of it on its side?
  4. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    We did take pics. Waiting to get them developed. It was dark outside and we used a flash, so hopefully they come out.
  5. chebywanna
    chebywanna 1/2 ton status
    Apr 20, 2003
    277
    streamwood, (chicago)
    a wire to my fuel gaugage broke one time (i was poking at it) and the thing always showed full, way full, past the point of can't fill it that full full, so you might have a wire problem.
  6. zooexhibit
    zooexhibit Registered Member
    Apr 29, 2003
    10
    Arvada, Colorado
    I recently replaced my gas tank and I was initially having the same problem. There are two wires that connect to the fuel filler assembly on the top of your gas tank. the guage wire and the ground. They connect to the top of your tank by a compression fitting. My guess is that either one of them has come loose or you have a broken wire. Hopefully it is just a loose connection because tracing the wire going up to the guage can be a little trying.
  7. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    iwas going to say the ground also. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  8. boggerless
    May 26, 2003
    22,728
    96
    untill i made it a little pick-up, trying was getting to my gas tank. icouldn't drop it because the hitch is welded all around the tank.the only way to drop it is to burn it off. that was TRYING. but alas she be fixed , arr maty. she's got no bed so i can reach everything /forums/images/graemlins/smile.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  9. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Thanks everone, I will try and see if it is the ground.
  10. BEHJR
    BEHJR 1/2 ton status
    Mar 28, 2003
    141
    Plano Tx USA
    Hmmmm, similiar problem with the K5-75. Except mine has all four feet on the ground as far as I know. Guage shows way past full. Empty show half a tank, as I found out driving it home from purchase. . Any guesses - float in the tank ??
    Thanks.
    Crankster. /forums/images/graemlins/angryfire.gif
  11. docgab
    docgab 1/2 ton status Premium Member
    Oct 1, 2002
    1,166
    Medford, OR
    If the ground is good, make sure you check the other wire as well and trace it back up the front of the frame. I had the same problem recently. Checked the groud, it was fine, traced the other wire up the frame and found a break. Fixed it and all was good.
