Gas Gauge?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **DONOTDELETE**, Sep 4, 2001.
    Does anyone else have problems with the stock gas gauge? Mine is unpredictable, I keep running out of gas, this last time it still read a half a tank. I was on the way to the gas station just in case and sure enough!!
    Is there a fix for this, with out replacing the tank.
    Thanks for any advice on this.
    '84 K5
    Chevy in my blood.
  1. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Sounds like a sending unit....which means lowering the gas tank.......If you would like to try another gas gauge I have one out of an '78?
    C'moe
    <font color=black>the blazer is "Back in Black"
  2. bee32
    bee32 1/2 ton status
    Aug 6, 2001
    401
    Virginia Beach Va.
    it sounds like the sending unit. Mine doesn't go above 3/8 a tank and doesn't go below an 1/8. It could be a bent float or something else with the sending unit. They are about 150 from the parts store but about ten bucks for a generic one. I haven't tried it yet because I haven't wanted to drop the tank to swap them out.
    Brian
    83 K-5 4" on 33's
  3. snomobilechic
    snomobilechic Registered Member
    Apr 13, 2001
    11
    Peyton, CO
    At least yours works. One day I went to fill up my tank and it went over to full and has only moved once since then. I am not sure why it moved that day, but it did. I keep track of my milage in a note book. Someday I might fix it, but that is really the least of the problems with my 1986 Jimmy...
  4. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    snomobilechic,
    Spund like yours is a short in the line.......
    C'moe
  5. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Generic? You mean from Autozone or someone like that? Mine doesn't go above 1/4 tank when full. I plan to drop my tank when installing my body lift and take a look. First I am going to check my baffle and see if it is hindering my floater. But, if I can get a new "generic" sending unit for $10, why not replace it while I have it down just in case? Where? Details!
    Brian
    Click to see <a target="_blank" href=http://tx85gmcguy.alloffroad.com> My 85 Jimmy </a>
    Who put a stop payment on my reality check?!?
  6. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    snowmobilechic yours is a bad ground wire
  7. dyeager535
    26,976
    One "test" of the sending unit is to "unground" the sending unit. With no ground, teh gauge should go to full. Without further diagnosis, could be gauge, wiring, or sending unit.
    Don't throw money at it until you know what "it" is
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
