GAS GAUGE
Discussion in 'The Garage' started by CHEVY 4WD, Mar 9, 2003.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    What would make a gas gauge mess up? Like dont give real good readings and when you fill up it stays full for a wile then then when you get low your LOW?
  2. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I would say the sending unit is going bad.
    Eric
  3. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    If you have dual tanks do you have 2 sending units?
  4. manyblazers
    manyblazers Registered Member
    Dec 13, 2002
    33
    toronto, Canada
    I had the same problem in my 87 jimmy. turns out the cover plate the sending unit and the gas lines run through into the tank was cracked. The whole sending unit and fuel pump would rock back and forth giving me bad readings. Had it welded and no more problem.
