Gas Guage doesn't work.
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by HIX, Mar 4, 2003.
  1. HIX
    HIX Registered Member
    Feb 26, 2003
    80
    Denver
    Gas Guage doesn\'t work.
    What are some common reasons for this?
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    Re: Gas Guage doesn\'t work.
    check both the power wire and the ground at the sending unit
  3. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    The float could have a leak too...
  4. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Does it read REALLY "Full" or REALLY "Empty"????
    The range of the sender is 0 - 90 ohms. I think that 90 Ohms is FULL, but I might have it backwards. Anyway, if theres a bad sender connection (too many ohms) the sender will always read TOO high....if it's shorted that could lead to a low reading.
    I'm not sure what the gauge does with no wires attached to it....whether it "floats" high or low.
    I had a corroded sender wire on mine and it always read over FULL. Once I cleaned up the sender wire it seemed to read much more accurately. FYI /forums/images/graemlins/cool.gif
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    [/ QUOTE ] it will read over full in about the 3 O'Clock position /forums/images/graemlins/shocked.gif
  6. HIX
    Feb 26, 2003
    80
    Denver
    It always reads empty.
    Well, one time it read 1/2 tank but dropped back down after a min or so.
  7. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    I'm kind of glad I caught this post. Mine is reading way over (like at 3 'o clock). I've been thinking about what the problem could be but have been putting off looking into it 'cause it'd be a pain without an idea where to start. Now I have something to go on /forums/images/graemlins/laugh.gif
  8. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    576
    Franklin,Ohio
    Also look behind the insturment cluster
    for a break in the panel
    that was my problem
  9. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Always reads empty? Sounds either like a short to ground in the sender wire or the sender bracket in the tank is broken (I had a broken sender bracket and it read empty most of the time until the lead between the sender and the sender wire snapped, then it read over-full).
  10. ErikH
    ErikH 1/2 ton status
    May 15, 2001
    112
    Southern California
    Are these wires attached to the tank? Which is the sending wire? I've never dropped a tank, but I have this same problem, and I'd love to fix it...
    "I had a corroded sender wire on mine and it always read over FULL. Once I cleaned up the sender wire it seemed to read much more accurately. FYI"
  11. Ryan B.
    Jul 18, 2001
    5,693
    CA
    If you can reach it, disconnect the connector off the sending unit, opening the circuit, the gauge should read full.
    Then ground the connector on the frame or something and the gauge should read empty.
    This tells you the gauge and the wiring up to that connector is good and it's gotta be the sending unit.
  12. Steve_Chin
    Mar 6, 2001
    1,126
    The sender wire is external to the tank. The lead to which I was referring is internal to the gas tank and can only be accessed by removing the sender assembly from the tank.
  13. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    if the wire is hooked to the tank and has a ground back there, check the path of the wire thru the drivers frame rail, make sure it isn't shorted somewhere. that's what my problem was, first time I removed my tcase the crossmember squished the edge of the wire and shorted it out. got lucky, I was fixing to buy another guage.
