Gas guage f'ed up!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ftn96, Jan 24, 2001.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Gas guage f\'ed up!!!
    I just filled up this morning adn 41 dollars later the guage was pegged at full. No problem.
    Then at lunch I was sitting at a light and noticed that the guage was now reading a little less than half. It wont budge when I floor it or slam on the brakes.
    Where do I start? I searched the archives, no such luck.
    Will work for parts, beer and sex.
    90 Jimi,350/700R4/241/10bolts/3.73's/33's/4"
    <A target="_blank" HREF=http://mccordhouse.freeservers.com>http://mccordhouse.freeservers.com</A>
  2. dyeager535
    26,982
    190
    Re: Gas guage f\'ed up!!!
    My guess would be sender, since if you lose ground, it should peg out and stay that way. COULD try making sure all the related contacts (fuel gauge, sending unit wires) have a good connection..probably easier than dropping the tank : )
    Dorian
    My K5 and Chev/Olds tech/links page: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
  3. behemoth
    behemoth 1/2 ton status
    May 16, 2000
    1,833
    Northwest Florida
    $41 is "no problem"? You using 97 octane from the most expensive station in town? I know - prices are a bitch - and I have the 23 gal. tank and I ask the attendant for loan papers everytime I fill up.
    behemoth K5
  4. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    LOL!! Well, it is a problem. But I have a 26 gallon tank and the octane was 87 and it is running about 1.40 round town here in Nashville.
    Update on the gauge. After it sat for a couple of hours between lunch and miller time, the gauge had climbed back up to full tank, then after about 5-10 minutes of driving, it just all of a sudden started dropping, all the way back down to a half tank. This is really too wierd, even for me.
  5. behemoth
    May 16, 2000
    1,833
    Northwest Florida
    I hear ya man. I paid $1.52/gal. in Louisville last week.
    Sounds like the sensor is going south on ya. I'd look into it since you don't actually know how much fuel you have - unless you stop and top off every two days or so.
    behemoth K5
  6. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Check the ground coming from the sending unit. Should be on the drivers side on the front crossmember that holds the tank up. Could have rust or corrosion on it that is affecting the reading. If that doesnt cure it, could be the sending unit. The plug on the back side of the dash may have some dirt or corrosion on it also, but more than likely it's the ground at the sending unit.
  7. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Well, hell, I drove all 13 miles to work today adn it stayed on full. So it appears to be working now. It usually stays on full for a couple of days before it starts to plummit towards E.
    Now that Im saying this, I'll go to the bank in a minute and it'll start freaking out again.
  8. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    this post is going to sound weird, but this is what I went through with my K5. when I had my diesel motor in the truck and I had the tank filled, it would read a quarter full when it was totally full. when the truck was empty it would read empty. When I switched the gas motor in and filled it, the gauge would read almost half full. then empty when it was empty. I noticed some of my lights in the dash weren't working, so one day I replaced some blown bulbs and made sure the gauges were having a good contact in the dash....well...WALA....the gauge now reads perfectly..I have a 31 gallon tank I think..the optional tank if thats means anything..and yes it used to drive me nuts too. so do all your dash bulbs work?? if not start there.....js
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Hey behemoth, be glad you don't have a Suburban! [​IMG] The tank on my '94 holds 42 gallons. Filling up that monster is painful on the ol' wallet! [​IMG]
    BTW folks, a bad ground won't make a GM fuel gauge read low. It will cause the gauge to peg past full. Somthing else is going on in the circuit to cause the flakiness reported above.
  10. Re: Gas guage f\'ed up!!!
    My gage never gets above 1/2 tank,but e is empty!LOL I'll fix it one of these days.
  11. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Harry's right. Typically 100 ohms= full, short to ground=empty. Have fun if it's wiring problem. NOT.
