Gas hesitation?
Discussion in 'The Garage' started by dasanii19, Dec 9, 2006.
  1. dasanii19
    dasanii19 1/2 ton status
    Oct 11, 2006
    344
    NV
    When I hit the gas at an idle it doesn't have much of a response I was hoping you guys can maybe give me a elimination check list I can go through to find out whats wrong? The only things I can think of is timing, fuel filter and air filter. what else can I do to get more response?
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    First off, what are the specs on your rig?
  3. dasanii19
    Oct 11, 2006
    344
    NV
    1976 k5, 350 4x4 , the carb that on it is a Quadrajet wit a number on it that says 7045213..
    Is that what you need? also is this a decent carb? How can I get more info on this carb?
  4. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    What size tires do you have? What axles? What gears are in em?
  5. GruntHunter
    GruntHunter 1/2 ton status
    Apr 28, 2002
    145
    Florida (Space Coast)
    Check for vacumn leaks around the base of the carb and around the intake manifold, that'll do it sometimes also :-)
  6. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    bogging out??..
    If it wants to die or bogs out on acceleration,it could be the accelerator pump isnt working right..if it just feels "flat" upon acceleration,it might be the secondary air valve butterfly isn't opening (on a Q-jet)...and all the usual stuff like timing being retarted,etc--also make sure the centrifical advance weights,and vacuum advance are working in the distributor(if it has a vacuum canister)......vacuum leaks are a definate possibility also,as already mentioned..:crazy:
  7. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Is this just when the engine is cold or is it happening after it warms up?
  8. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    When was the last time it had a complete tune up? New Cap, rotor, wires, plugs.?
