Gas Line
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Sep 29, 2002.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    I need to replace the metal gas line that goes from the carb to well wherever it goes to I m not sure where it stops before it gets to the gas tank. Nayways I need to replace that line so where can I get it at without paying allot of money or do I have to get a bender and do it myself?
  2. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    well try to get under the truck and see if you can find it and follow it back to the tank maybe you will see were all it goes then take it from there go to an auto store like auto zone maybe or something?
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I had to replumb my entire fuel system when I put in the TPI. I found some 3/8's brake line at an auto parts store and bent it myself. /forums/images/icons/cool.gif But it seldom comes in exactly the right length, so you need a double-flaring tool so that you can cut the tubing to the right length and then re-flare the end. /forums/images/icons/frown.gif
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    You also might want to pick up a cheap tube bending tool from some place like NAPA. I've replumbed most of my truck now (because I'm moving everything around) using nothing but straight sections, a bender, and a double flare tool...
  5. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    www.lmctruck.com has steel and stainless steel lines in stock. Not looking at the catalog now, but I believe the steel versions, fuel & brake, were less than $100...
    BlazerMan
  6. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    the hard line from the carb goes to the fuel pump on the side of the block. than a soft line goes from the fuel pump and connects to the hard line on the frame. from there i think its mostly hard line except for a few places along the frame.
  7. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    It would prolly be easier and cheaper to just buy a roll of rubber fuel line and use that from the tank to the block. I think standard low pressure line is about $1/ft which is all you need for a carbed engine. High pressure line for fuel injected engines is about $5/ft unless your lucky and the girl at Pep Boys rings up a 36 ft roll at the low pressure line price /forums/images/icons/grin.gif /forums/images/icons/wink.gif I'm redoing my entire fuel system tomorrow too since all my line is getting pretty rusty.
  8. dyeager535
    26,979
    GM used steel line for a reason. Use rubber line at your own risk, *I'll* never use rubber line where GM used steel, for any reason (tranny, fuel, oil cooler, etc) and I'd never recommend it to anyone.
    Way too many vehicle fires caused by people messing with the fuel system.
