Gas Pedal Problem
Discussion in 'The Garage' started by stockk5, Sep 19, 2004.
  1. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    The gas pedal on my 87 k5 is soo freakin stiff. if your weak in the legs you seriously can't drive my truck for a long time or you get to tired. What would be causing it to be so stiff when you press down on it?? Help! thanks /forums/images/graemlins/1zhelp.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    too many return springs? or maybe the cable is sticking to the housing,
    check your springs then get a cable from a junk yard.
  3. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Check the throttle return spring. Someone may have have moved one end further away to stiffen it up, or put a stiffer spring on at some point.
    Rene
  4. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    the spring is on the throttle body right?
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Drivers side of the throttle body, you'll see the linkage arm that the throttle cable attaches to. There should be a spring there too...and the spring makes the throttle 'return' when you let off the gas.
    Rene
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Do TBI engines have a carb like return spring? I've always just thought they use the one on the throttle shaft.
