GAS Problem Suggestions.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DuneRunner, Aug 17, 2001.
  1. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    I'm kicking my self running the cheep crap gas. 2 nights ago the K was runnen ok, then went to turn her off and she started to Desilate.(sp?) Once I felt that I ran to the Gas station and put the 92 in. Now I'm going to change the filter in the carb and the inline filter that my dad put in. Also add some more Gas Additative.
    2yrs. ago had the QuadJet rebuilt.
    WHAT ELSE DO I DO? Please give any suggestions......goin on a trip Labor Day weekend :)
    Thanks GUYS. KEN
    DANGIT it's not a bronco!
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    how much compression are you running with. try readjusting your initial timing and put a curve kit in it. It worked for me.
    ARQ.
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Where you been getting gas at? There's several stations around here (AM/PM in particular) where mine won't get out of it's own way if I run their product.
    Dos mas Tecates!!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  5. dyeager535
    26,977
    Thats not bad gas if you've got plugged filters..thats crap in the tanks. Or it could be crap in YOUR tank. I use the "cheap" am/pm gas exclusively in all my vehicles, as do my parents(87 octane, regular here) and can't say that it's ever caused any problems.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  6. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    I am going to put the octain in tonight as well as the new filters.
    I have used am/pm (arco) 87 for 3 yrs. now and that is the last time. I'm going solely on gut instinct and going to run 92 for a while and then 89.
    Thank you all for your suggestions.
    ARG what is a curv kit?
  7. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Try running Chevron or Texaco - both have loads of detergent in them and will do an A+ job of cleaning your system out.
    Dos mas Tecates!!!
  8. dyeager535
    26,977
    Contrary to what most think, running higher octane in a motor not designed for it is NOT productive. Of course it can mask problems such as too much timing, but it will hurt power output, and increase emissions in a motor not made to take advantage of it. Car mag even stated that for one of their buildups, they went back to "regular" on the dyno, because the premium was actually hurting the numbers.
    Besides, octane, AFAIK, doesn't have anything to do with the additive package in the fuels. Speculating, but I would think that for example, ALL Texaco grades have the same additives, just like all Chevron is probably the same way.
    Dorian
