gas smell in oil
Discussion in 'The Garage' started by k51977blazer, Mar 24, 2007.
  1. k51977blazer
    k51977blazer Registered Member
    Feb 11, 2007
    71
    Ashtabula ohio
    Well first off i have a 1977 blazer with a new 350 goodwrench motor about 1200 miles on it,Now its been about 3 years since its been on the road im restoring it.I changed the oil and it came out like water it was black and it had a strong gas smell to it.What would cause this smell and it to run out like that ,is it because it has set so long.Can anyone help with this problem.
    Thanks guys i appreciate it
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    The fuel pumps can leak fuel into the oil. The only thing that makes oil black is fuel dilution. You should keep your oil and filter changed every 3000 miles or whenever the oil starts to look dark or dirty. My best guess though is a bad fuel pump. I was only stating the other for your future reference.
