Gas tank access hole
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jackson 88K5, Jul 25, 2001.
  1. Jackson 88K5
    Jackson 88K5 1/2 ton status
    Oct 27, 2000
    104
    Topsham, Maine, USA
    I finally finished this long waited project of gaining access to my gas tank.
    http://home.midmaine.com/~tjackson/access%20hole.jpg
    <a target="_blank" href=http://home.midmaine.com/~tjackson/plate%20side%20view.jpg>http://home.midmaine.com/~tjackson/plate%20side%20view.jpg</a>
    If it breaks, upgade it.
  2. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    I was considering doing the same exact thing! It just seems to make sense. Have you noticed any downside?
    John
  3. Jackson 88K5
    Oct 27, 2000
    104
    Topsham, Maine, USA
    After removing the tank three times (one while in the middle of now where) It only makes it all better so I feel that there are no downsides to this project. The metal I used over the hole gives great support and with the rubber seal used I should have no leaking problems. I now carry an extra fuel pump in my middle console and the tools to get in the tank.
  4. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    What kind of pumps are you using that keep burning up? Are you running the truck out of gas? My brother kept burning up pumps (we put an in-tank in his '70), bought an AC Delco from Checkers and no more problems.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  5. Jackson 88K5
    Oct 27, 2000
    104
    Topsham, Maine, USA
    I'm still using the stock one. The two problems I have had was the rubber hose came off after doing some serious bouncing, and the other time the pump locked up but as soon as I took it out and hit 12 volts to it, it works and has been in there for 8 months. This last time I had it apart was to fix the fuel gauge.
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    looks great i am now putting that on my to do list[​IMG]
    77blazer see it at<a target="_blank" href=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</a>
  7. sb7979
    sb7979 Registered Member
    Apr 27, 2001
    9
    Ohio
    holy crap, your floor doesn't have any rust on it. you sure that's a blzer?
  8. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Wow, that looks great!! You don't have any problems angling the sender assembly out of the tank with that 1+ inch gap between it and the body?? That was what stopped me from doing this to any of my trucks.
    Great job!
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    **K5 - What more is there to life?**
  9. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    What did you use to cut the hole? Looks sharp.
    "I am Republican. Not a baby-killing, tree hugging, land grabbing, touchy feely, hypocrite wuss democrat!"<a target="_blank" href=http://www.handguncontrolinc.com>www.handguncontrolinc.com</a>
  10. COYOTE35
    COYOTE35 1/2 ton status
    Mar 5, 2000
    140
    Alto, Michigan
    I did the same thing to my Blazer last year. After having my fuel pump and sending unit crap out 3 times, I got tired of dropping the tank. I came up with the same idea&gt; Great minds think alike. I made my access hatch a little bigger so that I wouldn't have to fight any of the plumbing. Why Chevy didn't think of this I'll never know.
    Whats wrong with big and wide?
  11. Cusm
    Cusm 1/2 ton status
    Feb 25, 2000
    360
    OK
    Who you calling an... Oh wait that is access, sorry.
    Good lord. The rod up that man's butt must have a rod up it's butt.
  12. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Sweet! That's a beautiful job you did on that access panel; it looks like it belongs on an aircraft. Kinda reminds me of what I had my head buried in just a few hours ago...
    If at first you don't succeed, failure may be your style...
    [​IMG] <font color=green>Semper Maintenance!<font color=black>
  13. Jackson 88K5
    Oct 27, 2000
    104
    Topsham, Maine, USA
    Yep. That's the original floor.
  14. Jackson 88K5
    Oct 27, 2000
    104
    Topsham, Maine, USA
    The unit comes right out with a few angle movements.
  15. Jackson 88K5
    Oct 27, 2000
    104
    Topsham, Maine, USA
    I used my friend RotoZip tool. I used a whole disk on three sides and bent the metal back and forth until it gave. That's the left side, it came out the best. After using the RotoZip tool I will never buy my own. I thought it was an expiensive tool.
