gas tank filler neck question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JDBlazer454, May 25, 2003.
  1. JDBlazer454
    JDBlazer454 1/2 ton status
    Feb 27, 2002
    951
    Vancouver, Wa
    I am almost done with my 3" body lift and had a question about what to do about the gas tank filler neck? Of the other 2 trucks I put body lifts in I have never done anything with them but my 83 was stretched tight and needed to be disconnected. I didn't get the kit only the blocks so does the kit come with an extension? What to do? Please any suggestions would be great.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    goto auto parts house and get a longer piece of rubber gas line /forums/images/graemlins/thumb.gif that is what i did on mine....only other thing that i could think of doing is cutting the original line and extending it with an extra piece, i just opted to replace with longer piece.
  3. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    If you can find a new rubber piece designed for gas that'd be ideal. However, most of the time, all they come with is a piece of metal tube you use to extend it. You cut your existing rubber and put the metal one in with hose clamps.
  4. JDBlazer454
    Feb 27, 2002
    951
    Vancouver, Wa
    Thanks for the replies. I was being cheap and didn't get the neck filler replacement piece. We used a piece of exhaust pipe for the main one and a piece of high pressure line (for power steering I think) for the overflow.
    Thanks again /forums/images/graemlins/thumb.gif
