Gas tank flush?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigBurban, Jul 5, 2000.
  1. BigBurban
    BigBurban 1/2 ton status
    Jun 14, 2000
    237
    AZ
    I'm rounding the final turn on my diesel to gas conversion and need to flush the ol' gas tank. The radiator shops around town that do this type of work seem to quoting me some pretty high prices (a lot higher than I thought it would be at least). Is there a product on the market or technique that anyone's used for doing this themselves? BTW- The tank IS out of the truck. Thanks in advance! [​IMG]
    <font color=blue>~BigBurban</font color=blue>
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I would think that some type of liquid degreaser would work!
    As long as it evaporates after you dump out the dirty liquid. Then mabie finnish the job with a couple cans of carb cleaner.??
    Just guessing???
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  3. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    If it's that expensive would it be cheaper to get a replacement tank?
    89 K5 Silverado
  4. BigBurban
    Jun 14, 2000
    237
    AZ
    They want $85 to do the tank and I can't locate a descent used tank. All the new tanks I've priced so far are at least double that. I just looked on Eastwood's page and they make quite a few things for cleaning and sealing, but I'm starting to think I could probably just get away with degreasing the thing, powerwashing it, and following up with a light coat of WD-40 or something until I can get some gas in it. Over thinking projects will most likely be the death of me. D@mn this mind of mine! [​IMG] Thanks for the replies guys!
  5. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    How bout throwing a lit match inside? That would sure take care of any diesel leftovers![​IMG][​IMG]
    Now, seriously, Raybuck sells tanks for Blazers. I quoted one a while ago. It was only a little bit more than what a treatment costs. They are even treated to prevent corrosion. You might want to call them (800)334-0230.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
  6. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    Why not just run it with a bit of diesel in the tank? Some people add diesel or kerosene to clean out the carbon depisits in their engines, and as long as you have a healthy bit of gas in the tank too, I don't think you'll have too many problems.
  7. BigBurban
    Jun 14, 2000
    237
    AZ
    Well, after 18 years of diesel fuel having resided in the tank, there's quite a layer of caked black soot on the inside. The tank's already removed and empty, I just didn't want to slap the it back in, put gas in it, and have all that crap loosen. [​IMG]
  8. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    If there's enough crap in there that you wouldn't want to fill it with gas and go, you should probably bite the bullet and pay to have it professionally done. This way, you won't have to worry about using some chemical concoction whose fumes may explode if you think about a spark. AND, you won't have to figure out a place to dump the crap from the tank. That's my 2 cents...
    [​IMG] Semper Maintenance!
