Gas tank mount location
Discussion in 'The Garage' started by Thumper, Dec 15, 2004.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Is there any ill effects for the motor if a gas tank is mounted higher than the frame?
    I have a BBc with a stock mech fuel pump, and for my hybrid, the plan is to mount the stock tank on top of the frame rails in the center behind the cab. Everything should function normally right?
    Mike
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    should be no effect. The only thing you may want to think about is placement that far forward or high from a center of gravity and weight placement. If your project is going to stay how it looks in your avatar image the tank weight that far forward may be a bad idea. Namely with a BBC, an S10 cab(however lighter it may be) heavy front axle(not sure if you have a 60), a very light rear end could spell endo on a downhill.
  3. Thumper
    1,582
    Alberta Canada
    Naw, I just recently had the vision of how its going to be built. I am putting on the box (real short) and mounting the tank in the floor. I also have a Ramsey 8000lb winch to put back in the rear between the frame rails where the tank was originally.
    I dont think it will be too much of a problem with the weight thing, but I will watch it. :)
    Later
    Mike
