Gas Tank Mounting Brackets
Discussion in 'Parts & Trucks Wanted' started by 73k5blazer, Apr 17, 2004.
  1. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Looking for Gas tank mounting brackets from 86 chev truck, I think 84-87 will work, prior ot 84 they had a different location(s) in frame for mounting
    Long or short bed, right and/or left sides.
    The brackets the bolt to the frame, not the straps. (although if the straps are attached, that's ok)
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i have both sides from my 83, and im headed your way monday (ill be at Rockys Great Outdoors)
    how much are they different?
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    PM'd you...
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    locations would only be different between longbed and short bed, not because of year, shortbed tanks are shorter than longbed tanks is why, you can use 73-up straps and brackets, and they are reverseable you can swap to opposite side of truck and everything
    i have thrown away billions of tanks and brackets and straps and necks and units and everything, more than i could possibly recall, you are the first person i have ever seen thats looking for such brackets, is a rarity hehe
    good luck
  5. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I just want to put the passenger side tank in, this truck didn't have it from the factory. The mounting is a bit different btw. years, although I think the brackets from most any years would work, the holes have been moved and staggered a bit...just some drilling..if you check the GM parts book, GM shows different part numbers starting in '84 for those brackets...
  6. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Locations in the frame are different for long and short bed, the brackets are the same regardless..the rear one is just moved back a little on the frame...
  7. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    I bought brackets for an 87 from the GM dealer not more than 4 months ago. They were about 25 bucks each.
  8. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I checked there, they said mine were $32each, so $64 a side, and I need the drivers side as well because mine are so rusted, 40% of the bracket is literally gone..so I thought I'd check here first...
    Thanks..
    Ken
