Gas Tank Options?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rts, Jan 22, 2002.
  1. rts
    rts Registered Member
    Jul 28, 2001
    15
    Dallas, TX
    I have to drop the tank on my '89 K5.
    I don't know what tank I have, it is the stock one that came with the truck. I have the 350 under the hood. Does that help?
    Is a larger tank available? Is there some maintance I should do while I have the tank removed?
    Thanks.
  2. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
    If you do a search you should find some different discussions on alternate tanks you can use. One thing you might do while it's out is cut a hole in the floor over the top of the tank and make an access door so you can reach the sending unit without dropping the tank. After market tanks with larger capacities are available from AeroTank and JcWhitney if you do a search at http://www.ibiblio.org/rdu/p-sl.html
  3. Kman
    Kman Registered Member
    Nov 13, 2001
    22
    OR, Aloha
    I had to drop my tank in my 90, It was a 31 gallon tank. I beleive they came in a 22 gallon and 31 gallon from the factory.
    If you have a drop hitch you will have to take that off first.
    I beleive someone on this form just got a 40 gallon tank for there truck.
    Kevin
