gas tank problem and rear diff problem
Discussion in 'The Garage' started by irishraptor87, Apr 23, 2007.
  1. irishraptor87
    irishraptor87 1/2 ton status
    May 25, 2006
    141
    ct
    all this information is for a chevy 1986 k30
    ok, first off, today i went to the gas station and went to fill up, i was at roughly 1/4 tank (or so the guage says) stuck the filler in, started pumping, got to 4 gallons and click click done, hmm, so i clicked it a couple more times thinking wtf 4 gallons? took it out and i could see the gas all the way at the top, so i put it away and sat there, it bubbled down some and i put the cap on, i had to meet someone so i went of my merry way, while driving the gas guage went up some little by little roughly 4 gallons i would say to be fair, but it took a long time to get there, so i reached in the wheel well and found the filler neck, then found the smaller breather hose next to it, no kinks
    the truck has been filled several times in the past month with no problems
    is there another line i should check, where could it be clogged, what could be clogging it, please help
    secondly
    today i drove a little ways and i found oil near my rear diff when i got home, as if it had been spat around, almost like it was being spun (makes me think it was near the driveshaft) speckles of oil even on the inside wells of the tires, only in this area, no stains on the diff cover itself (so it must be before that) and nothing past the driveshaft, thus it must be in that area, it also has the very distinct smell of gear oil
    im thinkin a seal, which one?... any ideas or pictures of what one
    thanks for your help guys
