Gas tank problem... modification
Discussion in 'The Garage' started by Thumper, Sep 5, 2002.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I am still contemplating moving my gas tank from under the truck somewhere else. I cant shove it forward under the rear seat, there just isnt enough room. I cant afford a fuel cell, and besides there isnt that much room under my spare for a decent sized one. So... snoopin around, I found a behind the seat tank from an older style (57ish) Chev pickup. Just curious if anyone has any input on mounting this unit behind my rear seat. I just have to measure it for width... it may not go between the wheelwells. Does anyone know how many gallons they held?
    Thanks.
    Mike
  2. lizard
    lizard 1/2 ton status
    May 11, 2002
    114
    Tallahassee, Florida
    why do you want the gas in the cab with you? want to burn up faster?
  3. Thumper
    1,582
    Alberta Canada
    Actually, Id prefer not to burn at all... but having the choice... Id rather burn faster than really slow...
    Whats the difference? Separated by thin sheet metal? Or separated by thin sheet metal. Hmm. How do the stats compare to back when the pickups had the tanks there from the factory? Did anyone burn faster? Were there more accidents? Id almost think that its safer in the center of the truck compared to underneath and exposed. At least its protected.
    Any other opinions?
    Mike
  4. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    I had one in my old 68 F100 pick-up. I never worried about it...any collision that ruptured the tank would likely kill me anyways. Hell CJ5's have em under the drivers seat...poor man's ejection seat i guess /forums/images/icons/grin.gif
    I would cage around the tank if it fits between the wheel wells though and make sure it is well vented and doesn't leak. With a hard top on any fumes will quickly overcome you as you drive.
    Why not remove a gas tank sized piece of floor and move the existing tank up about 6 or 8 inches and then rebuild the floor above it? If I was going to custom mount a tank I'd do that...
    Rene
  5. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I saw an old K5 (69-72) a few months ago that had two saddle tanks on it, mounted on each side of the truck, right under the seats, outside of the frame. I wouldn't do that and don't advocate doing that, but just throwing that idea out there.
  6. Thumper
    1,582
    Alberta Canada
    Actually Rene... About the gas tank sized piece of floor... I kinda have a gas tank sized Ramsey 8000 winch there now! /forums/images/icons/smirk.gif I was looking closer at the tank, and theres not a chance its gonna fit between the fenderwells. So back to the drawing board! Hehe
    Mike
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I think the floors on K5's are too low for saddle tanks. The floors on Subs and PU's are raised where the seats bolt it and the tank kinda fits under the floor, at least on PU's.
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    There are aftermarket tanks out there that will mount in the saddle position on K5's. Aero Tanks sells a 45 gallon main tank and 18 gallon saddle tanks for each side. With that setup you could carry 76 gallons of fuel! /forums/images/icons/shocked.gif Hmm, that may be just what Greg72 needs, so he doesn't have to stop for gas every 100 miles. /forums/images/icons/wink.gif
