gas tank problem
Discussion in 'The Garage' started by chevy wrangler, Nov 19, 2006.
  1. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    okay so ever since i have had this truck the gas tank is wierd, when i pump gas in it stops pumping, like if the breather is cloged or something. i dunno what it is!! i have to pump really slow or else gas will come out its not full or anything i dont understand why it does this. so has anybody else have this problem?? does anybody know what it is or how to fix it?? plez help a kid out and thanxz:confused::confused::confused:
  2. ascuro
    ascuro Registered Member
    Sep 19, 2005
    62
    SoCal
    Mine used to do that same thing - only on slow-filling pumps, and when I filled it using a gas tank. Turns out my hose that goes from the filler neck to the fuel tank was a bit too long, and was forming a U-shaped dip (sorta like a gooseneck, like underneath your sinks). If it wasn't being pumped in fast enough, gas was collecting in the dip, and making the pump shut off...or in several cases, shoot gas out all over the place.
  3. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    inside the tank??
  4. goldwing2000
    goldwing2000 Guest
    Wow... I had almost forgotten about that issue!
    If you're talking about your pickup truck, it's pretty much normal. It's due to the fact that the fill hose is almost horizontal. When I had mine, I had to insert the fuel nozzle into the tank so it was only about half-way in, and then only click it to the first notch on most pumps.
    Fiddle around with the angle of the nozzle and insertion depth and you shuld be able to find a place that works better.
    Just keep an eye on it or you will, like ascuro says, end up spilling some.
  5. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    yeah its a pick up, with a fuel door. umm so its common???
  6. goldwing2000
    goldwing2000 Guest
    Well... it happened to me and I've talked to other people about it, so I figure it must be pretty common.
  7. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    my dads truck dosent have this problem, and it dosent have a fuel door
  8. goldwing2000
    goldwing2000 Guest
    I think the non-fuel-door trucks have a different fill angle.
  9. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    i'll check it when the sun comes out. so does anybody else have this problem??its starting to bug me now that my truck is my dd.
    thanks for the help so far guys
  10. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    and i also need a new sending unit for it
  11. ChickenRammit
    ChickenRammit 1/2 ton status GMOTM Winner
    Aug 21, 2005
    3,186
    FONTUCKY, CA
    yeah mine has always done that too. lately i put the nozzle in so that the hose from the nozzle is hanging at about the 8 o'clock angle and it seems to fill up no problem.
  12. ChickenRammit
    Aug 21, 2005
    3,186
    FONTUCKY, CA
    whats wrong with your sending unit?
  13. gmcburb1965
    gmcburb1965 clever user title
    Oct 29, 2005
    61
    Colorado Springs
    x2
    my 78 does the same thing, you get used to it though.
  14. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    the spring is all messed up and dosent mark the gas guage right
  15. ChickenRammit
    Aug 21, 2005
    3,186
    FONTUCKY, CA
    its not reading way past full by any chance is it?
  16. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    no its always @ full
  17. ChickenRammit
    Aug 21, 2005
    3,186
    FONTUCKY, CA
    does it ever fluctuate or just stay in the same position always?
  18. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    always there, when i dont start the truck for a week its like @ 3/4 of a tank
  19. ChickenRammit
    Aug 21, 2005
    3,186
    FONTUCKY, CA
    yeah i only ask because a lot of people think the sending unit is bad and all it is, is that the ground on it is loose or the wire to the guage is messed up or disconnected. just something to check before you go removing your gas tank.
  20. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    i already did and thats how i know its all messed up, the little spring that holds the float is messed up
