Gas Tank Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chevy305, Oct 27, 2006.
  1. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    What is conisidered to be the main tank and the aux tank on a 73-87 K10?
    Also how come I have yet to find any new or reproduction stepside driverside fenders that have a gas filler neck in them?
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I don't think there is any aux, they are identical and the switch goes left or right.
  3. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    I see in LMC and other parts catalogs talk about an aux tank.
    Let me put it this way what side tank came standard with only 1 tank?
  4. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Auxiliary tanks came in different positions.
    on older 67-72 trucks they had the tank behind the seat and auxiliary tanks went in the later model positions (saddle tanks).
    some tanks were installed in 73-86 trucks in place of the spare tire in between the frame rails.
    Then again LMC could be talking about the second tank as an auxiliary but nothing is different between the two to make one primary, not the switch, nor size nor location.
    I think the truck that I had with one tank had it on the driver side, but for the tanks them selves, they are interchangeable, side to side so it's the same part no if that is what you are trying to do.
  5. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    I was mostly currious, and I just had to order a new filler neck hose so I just wanted to double check I ordered the right part.
  6. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    You might be surprized but all the parts are interchangeable even the filler neck and hoses.
    :D
