Gas tank Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigwishlist, Jan 15, 2003.
  1. bigwishlist
    bigwishlist Registered Member
    Apr 14, 2002
    Sheboygan Falls
    Under my K5 (74) there is the front crossmember that holds the tank up. I am wondering if I can romove that member and make my own that goes farther forward. So I can get a longer flatter homemade fuel cell to fit. If I move the member more forward it will be above the rear diff. And I am wondering if the diff will make contact. Other than cycling the suspension to see clearance how will I know. So in other words...
    Can I move the front crossmember forward to make more room for a longer and thinner homemade fuel cell with out having rear diff clearance isues?
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    Sacramento, CA
    Yes you can but like you said you have to cycle your suspension to check for clearances, and do not remove a cross member without replacing it somewhere close.
