Gas Tank Questions
Discussion in 'The Garage' started by ihatefords, May 8, 2006.
  1. ihatefords
    ihatefords Registered Member
    Nov 10, 2004
    28
    Wyoming
    I have and 86 3/4 ton chevy longbox 4" Rancho Spring Lift(no blocks), and 3" body lift I need to know if a suburban gas tank( year 1986) <i think its possibly 40 gallons> will fit between the fram rails in the rear and if i have to cut the box out to fit it? Any pics or info on this would be appreciated
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I know they won't fit in a blazer so i'm thinking they won't fit into your truck either since behind the axle is the same if i'm not mistaken.
  3. huntingaddict
    huntingaddict Registered Member
    Jun 21, 2006
    44
    Bethlehem, GA
    tank
    I can't see how they would be the same as a blazer, the longbox trucks are surely closer to suburban length. I have one too and was looking at the same swap. If I get a chance in a junkyard, I'll post what I find.
