Gas tank removal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ArrowheadK5, Jul 31, 2002.
  1. ArrowheadK5
    ArrowheadK5 1/2 ton status
    Aug 3, 2001
    252
    Northern MN
    Are there any tricks to removing a rusted-on gas tank? It's a 16 gal on the dirver's side of my K20.
    I was told it was bad by the PO and so only use the othre one, and when the key is in the on position without the truck running, there is a whirring buzzing noise coming from it. Could this be the fuel pump trying to "prime" itself or something? I'm having electrical problems, so I want to rule out every possible electrical waste/issue. I am hoping if I drop the tank I will be able to unhook the power to its pump and wait to replace it until I have the $$. Any help is GREATLY APPRECIATED!!
    /forums/images/icons/crazy.gif Thank you very much,
    Tom
  2. ArrowheadK5
    Aug 3, 2001
    252
    Northern MN
    So I have to remove the catalytic converter? Do I need to remove all the exhaust from the back up, or can I just pull it out alone? And how the F*** can I do that??
