Gas Tank Replacement **Updated Confused**
Discussion in 'The Garage' started by burban89, Dec 4, 2006.
  1. burban89
    burban89 1/2 ton status
    Oct 16, 2006
    1,861
    Port Clinton, Ohio
    My 89 Suburban sprung a leak.:doah: How much trouble is it going to be to replace? All I have is hand tools no air. I have to do it outside no shop access. And the cold weather is here. I would rather do it myself to save some cash. The shop wants 350.00 to replace it. I can get a new tank for 125.00. Is it worth the hassle to freeze outside and do it myself?
  2. dremu
    Feb 27, 2000
    15,967
    459
    East of San Francisco
    Sure. PITA to drop -- drive it 'till it's empty first -- but it's doable. Figure on a pile of new hose clamps and maybe replace any of the filler hoses that are rotted, and easier if you have a way to lift/drop the tank (use a buddy, or one of these...)
    http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=2792
    -- A
  3. Smokin'Joe
    Smokin'Joe Registered Member
    Jul 27, 2006
    50
    Butler,Pa
    Spend an extra couple bucks for new straps. Every time I had mine out, at least one broke. Pick up a cheap bicycle inner tube to make some anti-squeek strips. One tube will do both straps. The less fuel the better. Hardest part is undoing and redoing all the lines, as you have to drop tank first. Probably only take about an hour, or so. I've done this with a screwdriver to unhook lines,and a few appropriate wrenches. Also remove the panel the license plate mounts to. This will allow easy access to the rear strap nuts. Hope this helps. Good luck.
  4. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    might wanna..
    While your under the truck,its a good idea too replace ALL the rubber fuel lines---I've seen a LOT of car fires recently around here,and the new 10% ethanol fuel is getting the blame--it's eating old hoses, and making them mushy and leak..there has been an epidemic here in boats with fiberglass gas tanks,and small engines are not dealing well with this new fuel either!..
    If you have TBI and an electric in-tank pump,you might consider replacing it while your there..I've had more than one croak shortly after dropping a gas tank for whatever reason..it sucks doing it TWICE,especially with no warm garage to do it in...:doah: :crazy:
  5. burban89
    Oct 16, 2006
    1,861
    Port Clinton, Ohio
    Now Im confused. Lastnight the truck hardly leaked any. And all day today it hasent leaked at all. So now what? Do I drop the tank and replace it anyhow. Or should I just keep an eye on it and see if it startes to leak again?
  6. krechj
    krechj Registered Member
    Nov 14, 2005
    33
    Murderapolis, mn
    is it possible the fuel just leaked to the point of being below the hole its leaking from? i've dropped mine, except i was dumb and it was almost completely full haha it wasnt to bad though... the only part that sucked was connecting all the hoses again when your trying to put it back in becuase there wasnt much slack in them so the tank has to be almost to the top and u really gotta squeze you arm in there to fit em back on
  7. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    Did you check the filler or vent hoses??
  8. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    My filler hose ain't in the best shape, so it leaks when I'm filling, or absolutely topped up, but 5 minutes of driving and it stops leaking.
  9. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Dropping the tank isn't really hard, just very awkward, just the two straps and the hoses for the fill neck. I would reccomend while you have the tank removed, or replacing, to go ahead and replace the fuel pump as well, it's another $40 or so, but it's insurance to not have to do it again for some time.
    If you can, have a friend help you with the dropping of the tank, because it won't just reach the ground,,,it will want to fall, but don't let it, the fuel, vent and filler lines are not that long.
    Don't forget about the power wires going to the top of the tank too, dissconnect from the clip up near the frame.
  10. lurtch-k20-(78-90)
    lurtch-k20-(78-90) Registered Member
    Nov 8, 2006
    55
    Troup, tx
    to buy some time until you can fixit or until it warms up, what ever, you can use a bar of hand soap and rub over the hole if you can find it. I do agree of installing a new fuel pump and suction filter, if memry serves correct the fuel lines are "high pressure ~ 52-60 psi" are hard crimped fittings to lines that screw into the line fittings. gasoline weighs ~7lbs/gal check at autozone o'reillys (your favorite parts house) for an electric fuel pump and a small dia. hose 1/8" to suck all of the fuel out, or take the pressure line off the back side of the trottle body slip a hose over and drain into bucket. If you can't get the atv lift (I have one, and it is very very useful, kinda like the pocket on my shirt. hope this helps
  11. Goss
    Goss Registered Member
    Nov 30, 2006
    12
    Grayling,Mi.
    Alot of good advice so far,..so I'll be the voice of safety.*clears throat and assumes a presumpteous stance.wagging finger*
    "Don't forgetcher safety glasses now,all that bumpin' around under that grubby old wagon is gonna shake loos a hella-buncha crap and a good deal of it right on yer head."
    It's $80 a pop to have rust flakes sucked outta your eye with a magnet at the optomotrist's office.Plus the drive over is a menace to other traffic.
