Gas tank sender question
Discussion in 'The Garage' started by bigwalleye, Oct 10, 2005.
  1. bigwalleye
    bigwalleye Registered Member
    Mar 7, 2005
    38
    Portland
    I got a 76 blazer with a 350, th350 tranny, 205 t-case, quadjet carb. I purchased a new tank and sender. I noticed that a manuel tranny has 3 outputs on the sender and a auto has a 4 output senders. I am confused what the 4th output is for.
    1-Fuel output tube
    2 - filler overfill tube
    3 - tank back persure tube
    4 - ??? :confused: :confused: :confused:
    On my current setup the 4th sender output was capped, just trying to figure out what it should be going to.
    http://www.carpartswholesale.com/store/index.php?cat=67&year=1976&make=CHEVROLET&model=BLAZER
    [​IMG][/IMG]
    SENDING UNIT
    Notes: 4 Outlets, 25 Gal., A/T, w/O-Ring & Strainer, (FG12D)
    Part Number: G670319
    OEM Number: 0
    List Price: $98.25
    Sale Price: $49.95
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    767
    Granbury, TX
    i believe its a vent line (ie plug it or run a line somewhere up high on the body)
  3. bigwalleye
    Mar 7, 2005
    38
    Portland
    Its odd if it is a vent line it is just designated for an auto. A vent line was my first guess also. Could it be a smog thing?
  4. mechted
    Oct 19, 2003
    767
    Granbury, TX
    i dont think so, my 73 has the same thing... they had very limited smog equipment back then
  5. dyeager535
    26,982
    191
    Fittings on the sender would be: (if every one ever put on was in place)
    Fuel out
    Fuel Return
    EVAP or Breather
    Fill neck vent
    Return is not always there, and if they ran a vented cap early enough, a vent on the tank would have been unnecessary as well. Emissions setup was very much based on final sale location, chassis, and drivetrain combo.
