Gas Tank Sending Unit
Discussion in 'The Garage' started by drofdar, Jul 3, 2005.
  1. drofdar
    drofdar 1/2 ton status
    Dec 7, 2003
    113
    Fresno, CA
    I decided to go with a custom gas tank for my 80 Silverado. Had to get rid of the saddle tanks. Since I decided to go with an external pump, anybody know of a good aftermarket sending unit? And I don't recall the ohm rating of the Chevy guages?
  2. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    Sending unit
    The company that made the tank you're using should be able to recommend a sending unit as well to go with it.
  3. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Most aftermarket tanks are designed use the stock sending unit. I know the aftermarket fuel tank I want to buy for my Chevy pick-up truck (with the exploding saddle tanks) uses the factory sending unit.
  4. drofdar
    Dec 7, 2003
    113
    Fresno, CA
    After Market Tank
    I was going to have one fabricated locally. What manufacturer did you have in mind? I'm want at least 30 gallons so I don't lose the range. The factory sending units will be too shallow to work with a deep, behind the axle tank. Since I'm going fuel injected, I am opting to use an external pump in case I have to do a field change. So I need a return line fitting. I just want to eliminate the dual bomb settup!
  5. LongIslander26
    Jun 25, 2005
    256
    Sending Unit
    The only modification you would have to make to a stock unit would be to install a return line fitting for the fuel injection, and probably a longer float arm to compensate for the increased depth of the tank. Most companies that I've seen that make custom tanks usually can hook you up with a sending unit to go with it. So it may just be a case of you buying a stock replacement, and having them modify it.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    0 to 90 is GM range
  7. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I am going to get a fuel tank from these people http://www.aerotanks.com/. They supply the sending units, filler necks, intank fuel pumps (if needed), and every thing for their tanks. The tank shown is a 45 gallon tank that bolts into the bed of the truck, directly behind the cab.
