Gas tank skid plate
Discussion in 'The Garage' started by WhiteBurb, Jul 25, 2005.
  1. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    I was looking at the original sales brochure for the 89 Suburban, and one of the options is fuel tank stone shield plate. Mine doesn't have it. Is it something worth looking for in a junkyard or is it just thin sheet metal or plastic?
    The gas tank is so far to the back of the truck, the only thing protecting it at all is the hitch.
    Thanks,
    Charlie
  2. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    There is a fairly heavy steel plate protecting the tank on my 91 Jimmy
    It seems to help lots off road , I would not remove mine because I think the tank would get damaged or worse without it
    I have had the truck drop hard on it a few times with no damage :whistle:
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    They're fairly beefy for a factory plate. The ones from the 70's actually wrap around the sides of the tank and have mud/water drains. The later models just cover the bottom of the tank. Check for clearance with your hitch though before you buy one.
  4. dyeager535
    26,982
    191
    I don't think they'll save your tank if you drop the truck on a rock right in the center, but it will certainly save the tank from debris thrown up by the tires, such as logs, etc.
    Last year out hunting I ran over a large branch that had fallen, and cringed as I heard it hit the tank. Luckily it just slapped the tank, and didn't hurt it. I just recently put the plate back on. :)
  5. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    A what for your gas tank? :haha: A bar of soap is your friend :thumb:
    It actualy got worse the next day :D
  6. msb350
    msb350 Registered Member
    Jul 6, 2004
    96
    Texas
    Its a heavy piece. I just removed mine and had the straps re-welded. Was fun getting it back on. Worth having though.
  7. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    yeah ive got one on my 79...i agree pretty functional for a factory part.
  8. WhiteBurb
    Mar 10, 2005
    307
    Louisiana
    Cool, thanks everybody. I'm going to keep my eyes open for one at the junkyards.
  9. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    1 thing to keep in mind, especially if you use the 31 gal gas tank, there is a gap between the tank and the skidplate (about 1/2" with the 31 gal tank) where mud and debris can get packed. Be sure to clean this area out. The PO of my '86 K5 didn't and the bottom of the gas tank rotted causing a small fuel leak leading to a fire while welding on an exhaust. Luckily the fire didn't hurt anything but the crap between the skidplate and the tank soaked up the leaking fuel so there was never a puddle under the vehicle or a strong smell of gasoline but the bottom of the tank was destroyed and the tank had to be replaced.
  10. dyeager535
    26,982
    191
    I drilled holes directly under the tank on mine, as when I pulled the original '81 tank, the bottom of it was fairly rusty, at least for what it should have been.
    There wasn't a whole lot of junk under mine, but IIRC, my old tank was much closer in proximity to the skidplate than my new one. I've got a good gap now, but I painted the bottom of the tank while I had it out for good measure. :)
  11. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    They're good to have, if you score one for free, or cheap. But, In my opinion, I would use it as a pattern to make a better/thicker one. I dented the one in my old K5, and as well as the one on my current K5. My old one was not too bad, but the dent on the 89 was enough to put a slight pucker in the tank. They are not *that* strong. I plan to use mine as a pattern for a better one. Just my opinion, for what it's worth.
  12. 79 blazer
    79 blazer 1/2 ton status
    Dec 29, 2003
    114
    FORT COLLINS,CO
    ive been considering just renforcing mine on the topside and the suppots with some, 3/8ths thick and 2 1/4" wide, flat bar that i use in welding class. it seems like that would be sufficient for my use.
  13. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    with the way the stock skid attaches I think it would be very easy to just reenforce the stock one
