Gas tank strap removal..
Discussion in 'The Garage' started by SS66, Sep 7, 2006.
  1. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    Is removing the bumper the easiest way to get to the bolts that hold the tank straps on my 88 k5? I can barely see into this area and know it would be impossible to get from underneath.. but dont want to go through the trouble of removing the bumper if that wont get me anywhere either.
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    It's not impossible to remove them from underneath, just takes some patience. Done it several times already.:crazy:
  3. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    its pretty easy if you have a swivle socket you don't have to mess with the bumper at all
  4. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    That said, removing the bumper does give you direct access to the straps.
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    My 89 if you open the tail gate the strap bolts are in plain sight and VERY easy to get to. :confused:
  6. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    Thanks for the help guys.. I guess I will be attempting to remove the bumper.
    I dare not try to open the tailgate... It will probably fall off if I do.. good ole Wisconsin rust
  7. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    No need for bumper removal. There is a trim strip between the bumper and tail pan. You can wiggle it out and get access from there. I just did this 3 weeks ago on mine.
  8. dyeager535
    26,982
    191
    You get better lighting and easier access/less in the way to pull the tank without the bumper.
    I've done it both ways, I'd rather not mess with the bumper in the way.
