Gas tank vent valve
Discussion in 'The Garage' started by Element, Apr 23, 2007.
  1. Element
    Element 1/2 ton status
    Mar 23, 2007
    Where's the vent valve for a K5's gas tank at? Took the gas cap off today and had a LOT of pressure buildup in the tank, to the point where I could only get about 8 gallons in it. Pretty sure the vent has to be either stuck or clogged up.
  2. dyeager535
    Assuming K5 in your profile, there are only two "vents" for the tank. The one in the cap (16PSI IIRC) and the EVAP cannister.
    I believe your evap cannister top will have markings on top of it, look for one referencing the fuel tank, see if you can blow through it with the gas cap off.
    The evap purge solenoid only operates when the truck is running, so I'd suspect something in the line to the EVAP cannister, or some sort of problem with the cannister itself, since the problem occurs during fueling.
