Gas Tank
Discussion in 'The Garage' started by ftcjimmy, Mar 28, 2006.
  1. ftcjimmy
    ftcjimmy Registered Member
    Mar 9, 2005
    61
    ct
    Im about to swap a pickup cab onto my K5 frame and i was thinking about gas tanks. I dont have money for a fuel cell so im wondering what the best option for getting the tank out from the stock location would be? how hard is it to move it above the frame? Would this be costly? Also would i be able to mount the side tanks off of my parts truck onto the sides of the blazer frames? Thanks
  2. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    I did somthing like this on my Suburban-buggy. I took the stock tank and swapped it on top of the frame in front of the rear axle. I used angle iron to space the frame in a little and set the tank down on the lip where the seam is at and I used the stock straps running to tabs on the sides of the frame to hold it down. Heres a couple pics.
  3. goldwing2000
    goldwing2000 Guest
    Nope. Not enough room between the rear foot well and the rear tire. It only works in pickups because the tank goes all the way up under the front seat.
  4. ftcjimmy
    Mar 9, 2005
    61
    ct
    Its goin to have a pickup cab on it. Still wont work?
  5. goldwing2000
    goldwing2000 Guest
    Hmmm... :thinking:
    It might.
    You'll have to measure it up once you have the cab in place. You'll probably have to modify the L-brackets, too. The frame bend won't be in the same place.
    Any reason you're that interested in putting the saddle-bomb on?
