Gas Tank
Discussion in 'The Garage' started by mbosmer, Nov 1, 2006.
  1. mbosmer
    mbosmer Registered Member
    Sep 6, 2006
    27
    Texas
    I bought an 87 k5 about a month ago but my gas gauge is messed up when my tank is completly empty it still reads 3/8 of a tank. Any susgestions?
  2. goldwing2000
    goldwing2000 Guest
    Probably excessive resistance in the circuit.
    Mke sure your sending unit is grounded properly. Check for rust/corrosion at both ends of the ground wire and along it's entire length.
    If it is ok, Check for rust/corrosion at both ends of the gauge wire and along it's entire length.
    If all the wires and connections check out ok, then it's either a bad sending unit or a bad gauge.
