gas tank
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by HEFTY, Dec 18, 2001.
  1. HEFTY
    HEFTY Registered Member
    Dec 18, 2001
    12
    connecticut
    when ever I fill my gas tank it takes about half a gallon or less and then trips the safety switch in the gas station nozzle and gas comes out of the filler on my truck. then the truck keeps taking gas. it is worse when my truck is very low on fuel. it doesn't matter what gas station i use. the newer style pumps seem to be worse. i haven't filled my 31 gallon tank in six months because it takes ten minutes plus to put in ten gallons. could i have a clogged breather tube? HELP
    75 K5 blazer
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Check for crimped/smashed filler tube also. You can probably see both hoses all the way to the tank.
    Mine always kicks off also unless you position the nozzle juuuuuuusssssttttt right.
    Dave
    Horn Broken... Watch For Finger.
    <a target="_blank" href=http://coloradok5.com/gallery/Daves-Pics>http://coloradok5.com/gallery/Daves-Pics</a>
  3. HEFTY
    Dec 18, 2001
    12
    connecticut
    Thanks for the help. i realized the nozzle trick when i first got the truck its just alot more sensitive now. i'll check the hoses.
    mike
