Gas Tanks and Gas Tank Sealers
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 72Blazerod, Jan 22, 2002.
  1. 72Blazerod
    72Blazerod 1/2 ton status
    May 18, 2000
    264
    Vancouver, British Columbia, Canada
    Hi guys, I have been away a while. Okay, I bought a gas tank from a 1987 Blazer and I want to put it in my 72 Blazer. It had nothing but the shell of the tank, will my gas tank inards (float, etc). fit directly into this tank?
    Also I want to lean and seal this tank before I put it in. What gas tank cleaners and sealers would you all suggest?
    Thanks guys,
    Rod
    <a target="_blank" href=http://communities.msn.com/72BlazerodsOldChevyTruckPage/truckstuffforsale.msnw?Page=1>http://communities.msn.com/72BlazerodsOldChevyTruckPage/truckstuffforsale.msnw?Page=1</a>
  2. JungleBoy
    JungleBoy 1/2 ton status
    Jan 31, 2001
    243
    Houston TX
    Rod
    I did this in the late 80s with my 67 Corvette tank, using the Eastwood system, a cleaner and a sealer. I thought the tank was very clean when I sloshed the sealer around, but.. Within 6 months (no more than a couple of hundred miles) the car started running bad - the carb was full of rust!
    Moral - whatever you use, be sure you get the thing clean before you apply the sealer. You are right to solicit recommendations. Good luck
    JB
  3. wrath
    wrath 1/2 ton status
    Mar 4, 2001
    182
    Grayling,Michigan
    Dude,I just came on here to do a search for this exact swap..I've got a 70 tank that looks like someone hit it with buckshot and was wondering if a 86k5 tank would work?I take it ,it will eh?
    70K5 350ci.350/205 "PROJECT 40"BOGGERS" It runs and its clean !!
    <a target="_blank" href=http://communities.msn.com/OurMudToys/the70k5blazer.msnw>http://communities.msn.com/OurMudToys/the70k5blazer.msnw</a>
  4. Tims72
    Tims72 Registered Member
    May 20, 2001
    39
    Lodi, Ca.
    Well I don't know about the tank swap, but I am getting ready to clean and line the tank on my 72. I got the tank liner from ChevyDuty.com It was around $25. The directions recommend "metal prep" or "solvent 100" to clean the tank with before applying the sealer. I am going to do the tank tomorrow I will let you know how it turns out.
    Tim
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    It can be done and someone around hear has done it...Just can't remember who.
    You have to turn the tank around (because the fill tube on 73-91 is on the right side) and remove the rear x-member.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  6. naranja72
    naranja72 1/2 ton status
    Jan 6, 2002
    110
    vancouver, bc, canada
    way back on 12/13/01, arq had posted some pictures of this swap. the link to the pictures doesn't work anymore. if i remember correctly he has a 2 or 3 inch body lift which helped him with clearance issues regarding the tank.
    good luck.
    marc
  7. tmanofcali
    tmanofcali 1/2 ton status
    Mar 20, 2001
    372
    lodi, ca
    hey guys....if your looking for pics of this swap go check out 1FNHIK5s webshots page. he has done the swap and i think theres some decent pics on his page. just thought i would let you know. later.........tmanofcali
    "When we were together, you always said you'd die for me.
    Now that we've broken up, I think it's time you kept your promise."
