Gas tanks & skid plates
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SuperUnknown, Apr 26, 2001.
  1. SuperUnknown
    SuperUnknown 1/2 ton status
    Feb 8, 2001
    165
    Prince George, British Columbia, Canada
    Well the "hole" in my gat tanks turned out to be "holes" and lots of them, so a new one is on the way and I have a few simple questions for y'all. First off what kind of paint/coating should I use on the new tank to protect from rust? and second where can I get a skid plate or a plan to build one or even just some good pictures?
  2. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    My 1990 came with a factory skidplate on the gas tank, so you might be able to find one at a boneyard, or maybe try a dealer. As far as coating the tank, find something good and rugged, that also ends up smooth (so it doesn't hold mud in as good) I've heard good things about POR-15. Let me know how it works out, the same thing is on my project list.
    Why do people keep calling it a Bronco!!!!! [​IMG]
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I never did find a good skid plate for my old 75 Blazer. That tank (seems like mine was 28 gal??) is in a terrible place! I eventually lost at least 5 gals (probably alot more) of capacity by caving it AND the skid plate in. There was a thin plate (factory?) on it when I bought it but it was quickly obvious that it was not sufficient. I got lucky and stumbled across a heavier one at a junk yard (looked home made but good) but even that didn't hold up. I always wanted to build a heavier plate but never got around to it.
    Anyways, my rambling point is that the tank is very exposed and needs some serious protection. I don’t think the factory plate is even close to strong enough for rock crawling. My K30 is getting a relocated tank above the rails (on the inside) and I’ll have to spend some time figuring out how to build plates for the rest of the exposed underside. A single heavy, bolt in plate from the engine oil pan going back past the 205 is my ideal but it will be hard to make I think.
    Hey, anyone got good pictures of good, heavy skid plates for gas tanks and/or other areas?
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56 Locked
    Soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I've got an idea for a gas tank skidplate - Fab out of 3/16" plate and weld 1"W by 1/2"D channel iron braces on the tank side. It wouldn't take too much to do, and would theoretically take all the abuse you could throw at it.
  5. AntAZBlaz
    AntAZBlaz 1/2 ton status
    273
    Mesa AZ
    i'd go with the por 15 i've used it my truck just make sure you follow the directions and it should turn out really good, i had a rusted battery tray that i used it on about 7 months ago it worked out well for me.
    Anthony
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I got a fairly beefy factory skid plate from a 70-something Suburban on my '75. It bolts to the frame in about 6 places and completely encloses the tank. It has drain holes so that mud doesn't build up between the plate the the tank. It's held up well, but I try not to slam dunk it onto boulders. [​IMG]
  7. Grim-Reaper
    7,385
    Atlanta
