Gas tanks
Discussion in 'The Garage' started by pennsylvaniaboy, Apr 18, 2007.
  1. pennsylvaniaboy
    pennsylvaniaboy 1/2 ton status
    Jan 28, 2006
    844
    pennsylvania, 15537
    ok guys im gonna be puttin sliders and a cage in my rig here soon and i have dual side saddles. i am thinking about putting a blazer/burb tank in the bed kinda like a fuel cell. but does anyone see an issue with putting a sidesaddle sideways at the front of my bed?
  2. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    I did on one of my trucks. fit perfectly under the tool box I was using. Make sure it is bolted down good and you have some type of grommet in the hole you run the fuel lines through.
  3. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    This is what you'll have if you add a Blazer tank to your longbed.
    http://coloradok5.com/forums/showthread.php?t=204679
    I did mine for different reasons but you get the idea of space used. If you want more bed space then the sideways mounted saddle will probably save you a good foot and a half.
  4. pennsylvaniaboy
    Jan 28, 2006
    844
    pennsylvania, 15537
    yeh see my sidesaddle's fit perfect under the bed box. big dan any sideeffects of doin that like side hilling etc
  5. Pvt. Maggot
    Pvt. Maggot 1/2 ton status
    Sep 27, 2005
    559
    Brownsville PA
    If you need a tank bro, I have one sitting around. :)
  6. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Like John's?
  7. pennsylvaniaboy
    Jan 28, 2006
    844
    pennsylvania, 15537
    lol thats cool but i got and 8' bed so i can throw a sidesaddle and on lose like and 16x16" by like 4' in the front of my bed and maggot ive been looking for you i gotta meet up before school is out and what kind of tank is that
  8. Big Blzn
    Big Blzn 1/2 ton status GMOTM Winner
    Jan 30, 2006
    3,587
    Orange County, CA.
    Huhhh??:D
  9. pennsylvaniaboy
    Jan 28, 2006
    844
    pennsylvania, 15537
    k take an 88' bed then take a sidesaddle tank turn it sideways and push it the whole way to the front thats what i mean
  10. Pvt. Maggot
    Sep 27, 2005
    559
    Brownsville PA
    The tank I have is a blazer tank.
  11. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    so you cant run sliders with the saddle tanks?:confused: even if you make custom mounts?
  12. pennsylvaniaboy
    Jan 28, 2006
    844
    pennsylvania, 15537
    yeh just wont be a supported as i would prefer. its a big truck and i like to build beefy. besides im not using the bed space for hauling. so its no biggie. does anyone see a problem running tanks this way
  13. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ive done several post recently about tanks in the bed (aux tanks, and fuel cells in the bed), but decided im just going to add a saddle tank on the left side. guess i might not be running sliders depending on how bad the mount is
  14. pennsylvaniaboy
    Jan 28, 2006
    844
    pennsylvania, 15537
    yeh they are cake to mount on the sides real easy if you have brackets. i got two brandnew tanks that came with my trruck when i bought it. but i will also be puttig in a cage that goes through the floor and to the frame which is another reason the tanks cant stay sidesaddle
  15. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    the only ill effects I had was when it wasnt bolted down very good. came loose while I was driving down the road and pinched the gas line.
    but personally if I had it to do over again I would add a blazer tank. I think it looks a little cleaner then having that odd shaped saddle tank layin in the bed.
  16. pennsylvaniaboy
    Jan 28, 2006
    844
    pennsylvania, 15537
    any one else see a problem?
  17. jones
    jones 1/2 ton status
    May 17, 2004
    379
    IONIA,MI USA
    Well, I haven't seen it mentioned yet, but I've been thinking of it lately. Why can't the saddle tanks be run side by side between the bedrails. I just don't know if there's room to do it, I haven't measured or anything. But if it could be done, you'd have the capacity for fuel, room to mount the sliders, and it would be easier to fab a skid plate for the fuel tanks. Say 10ga. sheet from framerail to framerail.
    Could someone measure the saddle tanks and between the frame to see if that's possible?
