Gas to diesel swap question
Discussion in '1982-Present GM Diesel' started by hidesertwheelin, Apr 29, 2006.
  1. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    I am considering buying a complete chevy 6.2 diesel truck to swap the diesel into my Suburban. Is it worth it to replace the 350 with a 6.2? Also does anyonw know ig the California engine swap rule of the engine coming from a newer truck apply to swapping in a diesel?
  2. tRustyK5
    Jul 23, 2000
    36,167
    1,364
    E-town baby!
    Is it worth it? That mostly depends on what your goals are for the truck...
    I think it was very worth it for my truck. Firstly it wheels so much better now that I'm not fighting a carb on every hill, and the off idle torque still amazes me. Secondly, I can afford to drive my truck again becasue the 6.2 gets double the fuel mileage that the 350 I had used to get.
    For drivability I don't feel I've lost anything...I wouldn't take my Jimmy to the track with either engine. It does just fine for regular driving and acceleration is comparable between the two motors.
    If your goal is to tow and keep up with the CTD's. D-max's and PSD's out there then I'd have to say it won't be worth it to you. The 6.2 wasn't ever meant to make the kind of power any of those three make (reliably anyways) It's definitely a light duty diesel, but in that role it does very well.
    The cost to swap in a 6.2 is usually quite modest too, and if you drive your truck regularly it will pay for itself in saved fuel in a pretty short time.
    I have no idea on the reg's in Cali for the swap you're looking at doing.
    Rene
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    In CA the same rule applies to gas or diesel, but the diesel doesn't get smogged so as long as the truck you get the engine from is from the same generation, there is no way the referee will know what year except by getting the numbers off and they don't do it.
    They look at the engine, it's a 6.2 so 82-93 fine, it's really attached to the truck and running on diesel, OK.
    Put TAG on it and never have to smog it again.
    :D
    If you want more info about CA laws, PM me
  4. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    So swapping diesel is a terrific was to beat smog regs, eh?
    Roz, you reading this?
  5. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Lots of peeps do this but be carefull.
    SOme cops pull over diesel trucks and check if they have gas engines.
    If you do this, remove any emblems that say diesel and make it look like any other truck so they won't have a reaosn to check.
    Now if you are putting a diesel just to keep it diesel and not smog, then that is what I did.
    :D
  6. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    I have acces to a 500 Caddy but I can't afford the mileage, want to be able to drive it a couple hours and possibly DD affordably. Prolly get a 6.2 permanently.
    Anyone want the Caddy? I will be pulling it out of a '76 Sedan DeVille complete, and I have another minus accessories that may or may not be good, haven't pulled it down yet.
