Gasket needed???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by flyguy33, Jan 4, 2003.
  1. flyguy33
    flyguy33 Registered Member
    Nov 22, 2002
    10
    Sacramento, Ca and Bay Area, Ca
    I just noticed theat in between my transfer case and my tranny there is a leak...then I noticed that there is only three bolts holding in in I was wondering if i could just tighten the thing up and replace the other bolt or do i need a gasket in between??? I just bought the truck and I'm finding these problems as i go along.... /forums/images/graemlins/shocked.gif
  2. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Put another bolt in it and tighten it up. If you're lucky it will seal up. If not you will have to pull the t-case, atleast pull it back some, which you would be doing anyway if you decided to do it to begin with. There is supposed to be a large o-ring between the adapter and tranny.
  3. flyguy33
    Nov 22, 2002
    10
    thanks for the info... By the way I noticed on your site that you're using a Comp Cam 4x4 cam, I'm just curious how the cam runs, and if its really worth pressing for....
