gasket or sealant or both....???
Discussion in 'The Garage' started by 55Willy, Mar 27, 2003.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I'm putting my 205 and sm465 together, just wondering if those old chunky gaskets are needed or can I just use sealant or should I use both????
    -Jeremy
    please stay tuned for the next mod......
  2. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    I don't know the answer so I will just make a smart alec remark so you know the post is not getting ignored..
    Weld them together and eliminate the gaskets completely.
    John
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I'd just use some RTV. Works for me. Just remember to NEVER use it near an auto tranny. It can and will make it fail. I know this isnt you case, but wanted to throw it out there.
    John /forums/images/graemlins/usaflag.gif
  4. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I just did this, first time I just did the gaskets filled them up with gear oil and everything started to leak by the next day. Replace the gaskets again but used this crap [​IMG] and several gaskets are still leaking. I am just going to let it leak. But next time I will use gaskets and some black rtv silicone.
  5. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    i bought a sheet of gasket paper and made my own gaskets.i put that and some black permatex on and i dont have any leaks there yet.just have to fix the other ones now. /forums/images/graemlins/smile.gif
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I like to use the gaskets with a thin coat of RTV on both sides. Just the gaskets is almost guaranteed to leak. Just the RTV is OK, but the clearances are designed to have the thickness of a gasket in there. Also make sure that the surfaces are clean and free of all old gasket material, grease and oil. I like to wipe 'em down good with laquer thinner since it will cut anything, and it evaporates fast and clean.
