Gasket replacement between transcase & plate
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigdaddy89, May 20, 2001.
  1. bigdaddy89
    bigdaddy89 1/2 ton status
    May 18, 2000
    422
    Phx, Az
    1. What is the simplest way to change the gasket that is between the transfer case and the mounting plate?
    2. Where would the fluid be leaking from at this gasket? Trans case or tranny?
    I think I sprung the leak from the frame twisting. Is there a way to make this area of the frame stronger?
    I have an 89 with a 700r4 and a NP241. Thanks.
    GOT ROCKS?
  2. bigdaddy89
    May 18, 2000
    422
    Phx, Az
    top
    GOT ROCKS?
  3. Blazerblk
    Blazerblk Registered Member
    Jan 23, 2001
    15
    Chicopee, Ma
    When I had to replace my gasket, I called all the part stores and they could not get the gasket. Just the seal. So I used permatex gasket/sealant. So far no leaks.
  4. bigdaddy89
    May 18, 2000
    422
    Phx, Az
    Thanks for the tip Blazerblk.
    GOT ROCKS?
