Gasket source for fuel tank filler neck "shield"?
Discussion in 'The Garage' started by dyeager535, Jun 28, 2005.
  1. dyeager535
    26,976
    I know this is a very niche product, but GM apparently doesn't sell them, and I had to actually replace the shield. This is the piece inside the bed on the K5 behind the passenger side wheelwell.
    Just wondering if anyone knows of a source for this thing. As my truck proved, this is a very critical piece, if the seal leaks, it rots the truck out in that area.
    For those that don't know what the piece looks like, it has a 90* bend where the bed meets the bedside, so making a gasket would be fairly complex.
    If no source, I'll RTV it, but if I ever have to pull it again, it will be hard to get out. Even with the stock foam gasket the old shield bent trying to pry it off the truck, I can't imagine how fun RTV would make the job.
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I just used some Fusor self-leveling seam sealer. worked great. Any seam sealer will work. The self leveling sealer flows a little nicer and makes for nicer presentation (like that has ever mattered to me LOL)
    Chris
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    www.lmctruck.com. They have the whole shield. RTV is probably your best bet if its just the gasket as they don't list the gasket in the Suburban catalog
  4. anjieandjohn
    anjieandjohn Registered Member
    Oct 31, 2004
    61
    Virginia Beach
    Filler neck Gasket
    The part number from LMC is 32-3332 and it costs 9.95...then add shipping. I have my catalog here at work so I can look at parts and list what I need...I have the 05 Spring edition BZC.18 catalog. You need to have that info if you order online.
  5. dyeager535
    26,976
    Thanks for the number/price.
    Seems pretty pricey, tube of sealant is probably half their before shipping price. :)
  6. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    I got both pieces from the stealership a couple of years ago when I swapped tubs. IIRC the gasket was more than the sheetmetal :crazy:
    James
  7. dyeager535
    26,976
    Maybe that was it...I didn't feel that a gasket was worth more than the piece it seals. :) Been a year or so since I checked.
    Sealant of some type is probably the best bet at keeping that joint from leaking, I painted over the stock paint to hopefully give it some more protection in the first place.
  8. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I have both new
    The gasket is just a oval piece of weather stipping.
  9. dyeager535
    26,976
    Yep, that's it! :)
    Gasket doesn't even have holes punched in it??
  10. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
  11. dyeager535
    26,976
    I've got some butyl tape, but my feeling on using it (or that urethane I suspect) is that if I've ever got to get that thing off again, I'd NEVER be able to clean it up or seperate it without a huge hassel.
  12. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    What about the white foam sealant in a can from DAP. You can spray it on and then when it dries trim the edges with a sharp utility knife.
  13. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    No holes punched in it. I would just get some weather stipping and call it good
