Gassy oil
Discussion in 'The Garage' started by 78Suburban, Oct 14, 2005.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    What is this a symptom of? my oil smells pretty strongly of gas, is this a tuning issue, or shot rings or what??
  2. Keith in CO
    Keith in CO Registered Member
    Jan 18, 2005
    27
    Canon City, CO
    gas in oil
    Could be a carb problem - sending more gas into the combustion chamber than can be burned. The bad news is that this condition can quckly wash the cylinders of oil causing rapid and premature wear.
  3. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    you could be way rich, what do your plugs look like?
  4. barneybasher1010
    barneybasher1010 1/2 ton status
    Sep 25, 2005
    908
    PORTERVILLE CA
    if you have a manual fuel pump it can be leaking gas into the crank case into the oil :k5:
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    X2
    :thumb:
  6. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Another for running rich. Had that problem before. Q Jets when they are ready for a rebuild are notorious for letting you know.
    John
  7. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Bad fuel pump
  8. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    dont run it to long as it will wipe out the bearings in the motor if it builds up to much. thats how i got my last truck cheep bad motor all bearings spun from gas leak in to motor.
