gauge bezel
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Jul 8, 2002.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    Has anyone taken he trim off of there gauge cluster. (stainless trim) If so whats behind it? Also does anyone know whatkind of light bulbs I need for the lights for the speedo and the fuelgauge???
    Thanks Brian
  2. beachinblazer
    beachinblazer Registered Member
    Apr 15, 2002
    20
    its just ugly black behing the aluminum. the bulbs are just regular instrument panel bulbs and the guages share them. while its off, you mgiht as well replace all of em
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I tried to clean,and polish the alum. trim. Didn't work,so I just pulled it off. I like the look of the all black dash..
  4. dyeager535
    26,975
    I pulled it off the dash trim piece on the drivers side, and it was just aluminum glued to the textured black plastic they used on the non silverado's. Problem was, the glue was hard, and with the texture, didn't look easy to remove. Maybe it is though, since somone has apparently done so. Since the black pieces were stock, you could just go get one from a yard if you wanted to.
