Gauge cluster interchangability
Discussion in 'The Garage' started by big94gmc, Nov 10, 2005.
  1. big94gmc
    big94gmc 1/2 ton status
    Sep 1, 2004
    3,651
    No VA.
    The five gauge cluster I took out of the '73 worked great, so it's a shame to let it go to waste. I'm going to eBay it and hope it gets picked up. But I need some info about it for the listing. What years shared the same gauge cluster as the '73 (with the speedo going to 100)? Wasn't it '73-'78? And, technically, this cluster could be used with any truck that had the mechanical speedo, right? What were those years?
  2. big94gmc
    Sep 1, 2004
    3,651
    No VA.
    ....Anyone know?
  3. dyeager535
    26,978
    I can't give exact year splits, but the differences between later (again, not sure exact years) and the '73 are going to be, at a minimum:
    Printed circuit board/instrument panel connector pinout
    Ammeter instead of a voltmeter
    Mechanical oil pressure gauge
    Speedometer cable clips to the cluster housing on yours, correct? Later ones do not.
  4. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    i dont know exact... but i put a 73 cluster in my 78 a while back..... then i was going to put a 86 cluster in my truck but didnt want to loose the factory tach and once I go with a cluster that says... unleaded fuel only need a catalytic converter - at least that is what they said at inspection and I didnt wanna argue with them.... :haha:
  5. drofdar
    drofdar 1/2 ton status
    Dec 7, 2003
    113
    Fresno, CA
    Small Hijack, but anyone know of a tach that will fit in the large fuel guage hole on the right side of these clusters? Then the fuel guage could live in the small hole on lower left. It only has the BRAKE light on mine.
  6. RootBreaker
    Nov 29, 2001
    5,117
    173
    what year?
    I have a 79 gmc cluster in mine.. factory tach...
    so I got the big speedo, big tach, small amp, temp, fuel, and whatever the fourth is... :haha:
  7. drofdar
    Dec 7, 2003
    113
    Fresno, CA
    I have two, 73 and 80. Both have the large fuel guage. 79 GMC would fit, wonder where I can get one?
  8. RootBreaker
    Nov 29, 2001
    5,117
    173
    www.car-part.com
  9. nstarry
    nstarry 1/2 ton status
    Feb 13, 2004
    349
    st.cloud minnesota
    I hope this is sort of what you looking for ?but the interchangebility will depend on the face trim right ??? my LMC catolog show a split for 73-75 76-87 but they dont sell the whole cluster, and the individual gages have a million splits. but the they sell the curciut panel thing for the back of the gage cluster and its split is the same 73-75 and somthing like 76-79, and all varies with tach or not! I would list it for a 73 and tell them to do there own research just to be on the safe side! I dont know if any of this helps at all
  10. BizeeB65
    BizeeB65 1/2 ton status
    Oct 12, 2005
    859
    Louisville, KY
    You putting that instrument cluster out of a 73 on ebay? Let me make you an offer first!
  11. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    if im not mistaken, the "factory tach" clusters didnt come in light duty trucks, only medium duty trucks, C60s and the like. there are a couple of guys out there that modify factory clusters to accept this tach, and a smaller fuel gauge. one of them can be found in the 73-87 area of www.67-72chevytrucks.com , although i cant remember his name at the moment.
