gauge cluster lights brighter info pics aslo
Discussion in 'The Garage' started by sweetk30, Nov 27, 2006.
  1. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    i had my dash apart so i figured why not try the chrome paint trick. so i took the cluster apart. wiped out lits of dust and removed all parts including cirkit board.
    then got some chrome paint and gave it 2 coats on the cluster insides and the back of the gauge cover also. then i got some ultra flat black and redid the front of the gauge cover.
    i have done some searching of bulb #s for there light output specs. to my suprize i found we might have some help in a diffrent bulb # . we basicly use the 194 bulbs as thay are comon and easy to find plus we assume thats whats in there. well his little brother is the 168 bulb.
    the specs are 194 = 2 candle power output.
    168 = 3 candle power output.
    so in short if we are looking for just a bit more of a edge on the dime gauge lights try the 168 bulbs.
    i just got done with the reassembly and will get bulbs after work tomarow. then i wwill plug it in and snap some pics for ya.
  2. my88texastruck
    my88texastruck Registered Member
    Oct 9, 2006
    37
    Northern Michigan
    Good idea, but as with any bulb, the brighter they are usually the hotter they get. With the gauge housing being all plastic you might want to watch for any melting if you have the lights on for any extended period of time. Although I don't think 1 candle power will cause any trouble in your application.
    Just my .02.
  3. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    cool man thanks! Id like to do that too.
  4. dyeager535
    26,977
    FYI, GM used both of those bulbs typically in the same housing.
    Some indicators and what not apparently needed to be more visually apparent, so you will see 168's used in some locations, stock.
    I too question the longevity of the bulb holders and surrounding cluster, as I've seen partially melted clusters, but it's not always from being a 168, seems entirely random, so who knows.
  5. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    that really looks good, especially the flat black. i should do that. a combo with bright bulbs and a good reflection should help alot
  6. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
  7. dasanii19
    dasanii19 1/2 ton status
    Oct 11, 2006
    344
    NV
    Did you get the dash back together? id like to see how it looks in the dark lite up now
  8. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I have had 168's in mine for almost 3 years. No melted anything yet. And I did the chrome paint thing a month ago or so. It is real nice at night.
  9. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I too have done the chrome and flat black paint and it is nice a bright if I can get all of the sockets to light the bulbs all at the same time:doah:.
    Ira
  10. dasanii19
    Oct 11, 2006
    344
    NV
    I got a can of semi gloss black paint, I see everyone is using flat, will the semi work ok? Are you using flat so you wont get any reflection or glare?
  11. sandawgk5
    Oct 28, 2003
    6,881
    I painted the gauge cover flat black it is the metal piece that goes between the gauges and the plastic lens. I supose you could paint that any color you wanted. I chose flat black to make it sort of disappear.
    Ira
  12. sweetk30
    Nov 1, 2004
    25,536
    533
    the truck dash is back togethor. i will take pics soon. but i can see a big diffrence to my eyes just in the shop.
  13. sweetk30
    Nov 1, 2004
    25,536
    533
    wow is all i can say. i just got to finaly test drive it around town at night. this mod works for sure.
    sorry no pics. i tryed but camera didnt like it to well. but the few bucks for the chrome in a can and 1 hrish to do well worth it.
  14. blazin' j
    blazin' j 1/2 ton status
    Aug 22, 2007
    841
    baton rouge, la
    Subscibed for future mod
  15. obijuan
    May 18, 2006
    4,009
    San Antonio TX
    still havent done it. story of my life.
  16. blazin' j
    Aug 22, 2007
    841
    baton rouge, la
    Lol, I've got two broken leafs on my ear drivers leaf pack that I'm waiting to fix..."if I'd have know then what I know now" is an understatement...
  17. sweetk30
    Nov 1, 2004
    25,536
    533
    slackers :haha:
  18. blazin' j
    Aug 22, 2007
    841
    baton rouge, la
    Rite rite
  19. Suecyde
    Suecyde Registered Member
    Aug 25, 2010
    36
    San Jose, Ca
    Sorry, I searched but could not find answers.... How do I remove the cluster? I get to the white part with all the bolts removed and it feels like something in the middle is holding the cluster back. I am guessing it is the speedo cable. But how do I remove this? Thanks
  20. sweetk30
    Nov 1, 2004
    25,536
    533
    metal tab thet needs to be pushed to the center of the speedo this will let the cable drop off.
    but the hard part is to the untrained person its a 2 hand job.
