gauge compartment
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mccomas, Sep 13, 2003.
  1. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    can someone tell me where i can pick up this stock (or reproduction) gauge holder; my 86 k5. it is the "aqua green" compartment that the stock gauges mount to and the printed circuit board mounts behind. i am doing some maintenance and this plastic piece has several panel light holders that are deformed to the point that my gauge lights will not stay seated. i can pick up the printed circuit from lmc but can not find the gauge compartment anywhere. suggestions....
  2. big d
    big d 1/2 ton status
    Oct 24, 2001
    1,236
    illinois
    cheapest place would be a salvage yard. ive seen new go for close to 100.00. there was a couple on ebay, do search under k5 blazer. hope this helps. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  3. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Please fill out your profile so we know who you are and where you are. Maybe someone close to you can help IF they knew where you were. As said above, try the salvage yard. And welcome aboard.
  4. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    I may have one (NOS/New Old Stock) I'll be back home this evening and I'll check it for ya... /forums/images/graemlins/deal.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My question is, where's the first place to look if your dash lights are out? I let my truck sit a year and it all of a sudden has no dash lights.
  6. mccomas
    May 30, 2003
    262
    Fayetteville, NC
    behind the plastic compartment that holds the gauges there is a printed circuit board (it is a flexible board). take a circuit tester and see if you have voltage where the individual panel lights plug in. when removing the entire cluster, it is easer if you feed a bit of speedo cable through the engine compartment once you remove the screws. with the tension removed from the speedo cable, the cluster will pull away from the dash much easer...
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Oh screw that then, I guess it's time for the full autometer setup for me. /forums/images/graemlins/smile.gif My tach lights up that's what tells me my speed anyway.
