Gauge help
Discussion in 'The Garage' started by RodsRVF, Mar 13, 2006.
  1. RodsRVF
    RodsRVF Registered Member
    Mar 16, 2005
    51
    CA
    I am looking at buying a stock gauge cluster that has a tach. My gauge cluster has the fuel gauge where the tach is on this unit. I did a search and could not find anything on this conversion. Anyone done this before and if so what was involved?
    Thanks for the help,
    Rod
  2. dyeager535
    26,982
    191
    If you get the whole cluster, you will likely need to re-pin the connector that plugs into the back of the cluster.
    Be aware of differences like mechanical oil pressure and the ammeter used on early clusters.
  3. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    what he said...
    I got the factory tach unit.. and all I had to do was move the wire for the fuel gauge...... did you get the factory plug wires for the tach with the unit you got?
    I basically got a full truck and tach was bad.. so bought another factory tach unit.. complete.. and tach was good..... :bow: $25 to my door :bow:
