gauge lights ?????
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 70k5b, Feb 18, 2004.
  1. 70k5b
    70k5b Registered Member
    Sep 23, 2003
    36
    spreckels ca
    i have a 70 and a 72 blazer and neither of there gauge or dash lights have worked,
    i bought chiltons and that dosnt explain anything, is there anything that anybody knows about this;.
    /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/confused.gif
  2. crawford
    crawford 1/2 ton status
    Feb 13, 2004
    229
    Vancouver, WA
    The back of the dash has about 10 twist in lights. If you look under the dash you should be able to see them all. Make sure you have a light for each spot and make sure they all work. I was able to get replacement bulb and a new twist part at Napa.
  3. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
  4. 70k5b
    Sep 23, 2003
    36
    spreckels ca
    ive taken the instrument panel off and replaced every light and cleaned the connecters, i wish those wiring diagrams were a little better looking,
    Thanks for the help
  5. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    I know it sounds stupid, but have you tried turning the dimmer on the headlamp switch?
  6. 70k5b
    Sep 23, 2003
    36
    spreckels ca
    yes at first i thought it could be the switch but still no luck,
  7. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    Then I would say test the ribbon board behind the gauges.
  8. 70k5b
    Sep 23, 2003
    36
    spreckels ca
    ill try the ribon,
    thanks for all the help
