Gauge Pods
Discussion in '1982-Present GM Diesel' started by laketex, Feb 4, 2005.
  1. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    What gauge pods are you guys running in your '73-'91 diesels? Where did you get them? I need to install a couple gauges in my crewcab and am having a problem finding the pods aftermarket. Thanks!
    Bryan
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Only options you have are dash mounted stuff. No one produces an A pillar pod for our trucks unless it's happened in the last few months.
  3. laketex
    6,220
    North Texas
    I know summit sells a TON of apillar pods for different applications...do you think another vehicle might be similar enough that it's pod might work with slight mods?
    I really haven't seen a dash gauge that I liked...maybe i can fab something up under the dash near the middle.
  4. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Do all the old diesels have like NO gauges, or is it just the CUCVs? I've never had a vehicle with no temp gauge at least. All I have is idiot lights besides fuel, speed, and voltage. And how do you really know if the oil pressure idiot light is actually working...
  5. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    If the engine is not running but the ignition switch is in the "Run" position the light should come on. That is the only way to know if it is working.
  6. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,034
    1,083
    Dallas
  7. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Look good! Question on the boost gauge - is 15 the most your setup will see?
  8. AgDieseler
    Jan 25, 2001
    1,034
    1,083
    Dallas
    Probably not, but I sure won't go far past that without an intercooler. Someday, I'll upgrade to a 20 psi gauge.
  9. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    How much do those 3 gauges cost? Individual prices would be cool too, im killing for a Tach in my truck, boost would be cool to, how do those boost gauges work anyway?
  10. AgDieseler
    Jan 25, 2001
    1,034
    1,083
    Dallas
    They're not cheap. Isspro makes them for Banks, so that may help you find a deal somewhere.
    www.dieselpage.com
    They sell a lot of Isspro stuff, so check them out.
  11. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Just got my new JCWhitney Truck catalog, and they have "generic" A-pillar gauge pods for 2 1/16" gauges, in single, double, and triple models. The ad says to use a heat gun to form the pod to your pillar (makes sense...). I think the triple was $30, single and double a little cheaper.
    They're probably not the prettiest pods out there, but they'll do the job. I'd get one if I was running the small gauges, but since I've started a collection of Autometer Sport-Comp 2 5/16" gauges (or whatever the bigger ones are...), it won't work for me.
  12. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    "Autometer Sport-Comp 2 5/16" gauges (or whatever the bigger ones are..."
    I found that same pod at a local store tell I noticed the gauge size cause I have the same size of gauges your talking about and I dont like those little dinky ones for that pod. I'm thinking about making my own pod for the 2 5/16" gauges.
  13. dallassnowman
    dallassnowman 1/2 ton status
    Sep 14, 2003
    339
    Forney, Texas
    How can I put a tach in my stock 6.2?? Where do I hook it up to???
  14. eclipse
    Jan 1, 2005
    1,245
    Sparks, NV
    I dont think Diesels are like gas with tachs. You dont have an igintion system to run a tach. I thought I heard once you had to have a gear for a tach on a diesel, I'm still learning diesels myself here.
  15. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    You can run them off of the crank pully, alternator, or injection line pulses.
  16. savagek5diesel
    savagek5diesel 1/2 ton status
    Nov 20, 2003
    310
    Redding California
    larger shift tach question.
    I've also heard you can run a tach of the alternator. With that in mind, i've looked through summit and they have adapters to run their larger 5" tachs off of the alt. I was wondering if us diesel guys would be able to use that setup? because i would like to run their 5" in dash tach with a 5" in dash speedo with misc. guages in the other 4 slots.
  17. jarheadk5
    Mar 6, 2000
    4,389
    PA
    I'm thinking the same way, but I'm not gonna go full-pod. I'll probably just bend up some .062 aluminum sheet with the correct-size hole(s) for the gauge(s); this way I can put them at the angle that suits me.
