Gauge Questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SummitXMK, Jul 27, 2001.
  1. SummitXMK
    SummitXMK 1/2 ton status
    Jun 6, 2001
    I am in the process of changing over to the gauge cluster with the stock tach and have a couple of questions. What type of plug to I need to plug into my distributer for the tach. And this new cluster has a mechanical oil pressure guage that has a metel line that has been cut. Where to I get this line and where does it go on my motor. Last but not least one of the ends in the flimsy copper panel is torn off so the gas gause won't work. Is there anyway to fix this? If not where do I get a new one. NAPA or do I have to go to GM? Thanks in advance for all the help.
    78 K5 Cheyenne 400 th350 203 With lots of miles
    <P ID="edit"><FONT class="small">Edited by SummitXMK on 07/27/01 10:03 AM.</FONT></P>
  2. Michael
    Michael 1/2 ton status
    Sherman, Texas
    A .250 Female spade will plug into the distributor terminal marked "TACH". You can replace a piece of circuit board by carefully soldering a piece of wire onto the ends that are still there. With a razor blade, you can scrape the plastic coating off the copper trace and solder a wire there. Don't use too much heat or the plastic will melt.
    If the end is torn off where the plug goes you might make a wire jumper from the correct wire (brown I think) to the terminal on the gauge.
    <a target="_blank" href=http://jmartin.net/parker/goose.htm>jmartin.net/parker/goose.htm</a>
    <P ID="edit"><FONT class="small">Edited by Michael on 07/27/01 11:50 AM.</FONT></P>
  3. dyeager535
    Be careful of the gauge cluster itself. Friend melted a tach dash trying to put it into another year, without checking the wiring layout. What a waste.
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
