Gauge Testing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beefcake83, Sep 22, 2000.
  1. beefcake83
    beefcake83 1/2 ton status
    Jun 24, 2000
    240
    Alaska
    My volt guage went out recently, and I'm trying to find out if there's a way to test it out before buying a new one and finding out that didn't cure the problem. I thought I was missing one of the metal clips to make the electrical contact on the instrument cluster, but turns out all of the clusters I found in the junkyard don't have this clip. Why a hole was made in the cluster if it never used a clip in that location from the factory is news to me. I may have to check my sending unit too.
    Gary Graham
    '83 GMC Jimmy 350 'Beefcake'
    Eielson AFB, Alaska
    Metallica & Mountain Dew
  2. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    I think you can run a continuity tester between the leads. If that doesnt work get a 6 volt latern battery and connect it up, should read half way to the twelve. Run two in series(?) and you can make it 12 volts.
